jal123ddd Posted March 12, 2013 Posted March 12, 2013 hi all agin on here ,dose any one now why the front forks on my sons py90 seem to sag a little in which way i maen is they seem to go in about 1 1/2 inch when the bike gets sat on only seen this happening the last to weeks or so any info on this lads or ladies will be great Quote
eastanglianbiker Posted March 12, 2013 Posted March 12, 2013 can you see any sign of oil leaking out of the forks where the seals might of blown that would make it sit lower/sink when st on Quote
jal123ddd Posted March 12, 2013 Author Posted March 12, 2013 hi there thanks for a reply on i can not see any oil leak or could you say i may need to bleed the old oil and put new in but thinking of after puting the question up i was haveing trouble with the front break and i have adjusted the arm on the drum by riseing it a fuw notches up which the break works a lot better and have only seen it since then Quote
eastanglianbiker Posted March 12, 2013 Posted March 12, 2013 mgiht be the brake is working better then as that will pull the forks down/make the front end dive more if brake is gripping harder have you ever checked fork oil levels or changed it that might help and use slightly heavier oil in them Quote
jal123ddd Posted March 13, 2013 Author Posted March 13, 2013 no never checked them before so i will check the oil in them do you have any good suggestions on a good oil at all and will let you now on this thanks for the info on it Quote
megawatt Posted March 13, 2013 Posted March 13, 2013 The suspension is supposed to sag a bit when you sit on the bike.? Quote
