Guest Posted April 27, 2013 Posted April 27, 2013 Hi guysRight, i normally know my way around a carb, But for some reason, The one on my bike is giving me some jipp..BAsically, its been running rich, very black and sotty spark plug..Top end revs the engine seams to bog down and have no power for a while, but then suddenly picks up with a bit of spluttering..I have adjusted the needles on the carb, to have no help..Basically, either needle i seam to adjust, never does it...So, to be on the 100000% safe side...Exactly what needle is the air/fuel mixture on this carb?because like i said, no matter what needle i adjust, and no matter how much i adjust it all.. It doesnt seam to change much..http://i365.photobucket.com/albums/oo92/Badboyazza_2009/KGrHqZpE-1Qr1qjbBP1GU25co60_58_zpsbb15074e.jpgcheers Quote
eastanglianbiker Posted April 27, 2013 Posted April 27, 2013 not sure which of them might be the mixture needle have you checked the air filter to make ure its clean and have you had the cable out of the carb and changed the setting on the needle that goes down through the slide as that normally has 4 or 5 grooves on it and a circlip to set it with Quote
Guest Posted April 27, 2013 Posted April 27, 2013 Yeah ive checked everything..Its a sheng wey. Cheers Quote
megawatt Posted April 27, 2013 Posted April 27, 2013 A better picture of the jets might help? If you can only see a screwdriver slot, screw it in while counting the turns, then screw it out to remove it and take a picture. Check O ring and seating of jet needle if it's a pilot jet. Quote
acting_strange Posted April 27, 2013 Posted April 27, 2013 I believe this will give the answer that is needed...http://my.opera.com/linuxjunkie/blog/in ... Wey%20PD16 Quote
acting_strange Posted April 27, 2013 Posted April 27, 2013 Found a note that said the Sheng wey is a copy of the Waldro and therefore have found this whioch may help...https://dl.dropboxusercontent.com/u/227 ... ETOR-1.pdf Quote
Guest Posted April 27, 2013 Posted April 27, 2013 Ahhh huge help. Thankyou..Couldnt find sprcs anywhere. Well i will rip my carb off lwter and see how i get on..Thanks for yiur help guys Quote
