jal123ddd Posted May 25, 2013 Posted May 25, 2013 hi all agin new problem here which is the gears I think my bike will start and run as it did before but there is a knocking like sound comeing from the back part of the engine I took the gear caseing off the other day and replaced a new spring for the kick start but I knocked the gear stick when the engine was open and I have semed to put it all back together but this knocking sound starts when the engine is running and it is making a knocking sound when I push the bike with the engine off or when I turn the fly wheel and one of this thanks Quote
jal123ddd Posted May 25, 2013 Author Posted May 25, 2013 forgot to say when I put the engine in gear the knocking will stop and I can not get it out of first gear f**k knows what I have done help Quote
eastanglianbiker Posted May 27, 2013 Posted May 27, 2013 i did reply to the pm you sent me about it Quote
rennie Posted May 27, 2013 Posted May 27, 2013 I haven't got a clue without seeing it!It sounds like it's something you've done so take itapart and do it again. Quote
oslin06 Posted May 29, 2013 Posted May 29, 2013 sounds like you have moved the gear selector drum/linkage and it is now in a position it should not be, as said above take it apart again and inspect it all and make sure the selectors are in there detents correctly.Keith Quote
