buggerit Posted September 8, 2013 Posted September 8, 2013 Ill keep it quick so not to bore you all. If I swap mini indicators with a bulb not leds for my massive street light size bulb indicators can I do a straight swap. Ive heard lots of issues with swapping indicators going to leds so I thought fo for mini bulbs!!! Quote
Tango Posted September 8, 2013 Posted September 8, 2013 As long as the bulbs are the same wattage as the original ones you shouldn't have a problem..... Quote
Chrissb6 Posted September 8, 2013 Posted September 8, 2013 More than likely you will have issues if your bike is fitted with standard 21 watt lamps. Check the wattage of the one's you want to fit against the existing one's. Led lights are far brighter than the low wattage one's you want to fit, personally l think the low wattage lights are a bit dodgy particularly in bright day light. Why do you want to change? Quote
buggerit Posted September 8, 2013 Author Posted September 8, 2013 Im just trying new things its an older bike and maybe not one everyone would change much on but its looking ok and im just sprucing it up. Its cheaper than buying another for now lol. The standard bulbs I have are pretty good regarding light brightness just very chunky. Quote
Chrissb6 Posted September 8, 2013 Posted September 8, 2013 Hi, the standard bulbs will be 21 watt as spec, dow't very much that your miniature lights will be 21 watt and as a consequence you will find that they will not flash at the normal speed if at all! Resistors or an electronic flasher unit might be called for, all ready available on flees bay Quote
buggerit Posted September 8, 2013 Author Posted September 8, 2013 I have seen 23Watt mini bulbs could I nor use these or would they be too much? Quote
Chrissb6 Posted September 8, 2013 Posted September 8, 2013 I have seen 23Watt mini bulbs could I nor use these or would they be too much?No they will be fine Quote
buggerit Posted September 12, 2013 Author Posted September 12, 2013 fitted my indicators today and they came with 23watt bulbs, straight fit so nice just to have a job thats easy for once. massive difference very happy Quote
Chrissb6 Posted September 12, 2013 Posted September 12, 2013 fitted my indicators today and they came with 23watt bulbs, straight fit so nice just to have a job thats easy for once. massive difference very happy Nice one! Always expect the worse, then a result should be in order. Quote
