you will need to measure the intake diameter side of your carbs ,but personaly if it is running fine on std airbox i wouldnt mess with it as once you fit the k&n's you will need to start rejetting the carbs to compensate the fuel air ratio difference
:stupid:
I fitted k&n's to my xs1100 years back.......it never did run as well despite spending ages messing around with the jetting...... :roll:
