Guest Posted September 18, 2013 Posted September 18, 2013 Hi all. I have a '59 plated terra. Great bike but only issue is that the odometer and clocks keep resetting, does anybody else have the same issue or fixed. Help please Quote
Mr Fro Posted September 19, 2013 Posted September 19, 2013 When are they resetting? If they do it at start up then you may have an iffy battery - it might also be a good idea to check your charging system. Quote
Guest Posted September 21, 2013 Posted September 21, 2013 My friends Derbi GPR used to do that.Everytime he turned the key off, it cut all power and the clocks would reset..I fixed this issue by giving it a constant positive feed..On his bike, he has a yellow wire going into the rear of the clocks, that was its continous positive point. i then soldered and heat shrunk a 18awg wire to that and conencted it to positive of the battery.It fixed the issue.... Quote
