Hi all. My kawasaki er6f is leaking oil from the water pump. I have replaced both oil seals twice now and i cant figure out what it is. Any Idea's?
Which seals have you replaced?......the seals from the drive that turns the pump? The only place that the oil can get there is through the seals in the crankcase where the drive comes through.....unless the leak is somewhere else, but emerges from the water pump housing. The water pump isn't anywhere near the front sprocket cover is it?.......not oil coming from there and seeming to appear from the water pump?..... :wink:
