Tango Posted January 23, 2014 Posted January 23, 2014 Hello chaps.......just wondering if anyone has replaced the standard coils on an older bike with Ignitor Sticks/caps? Just wondering if I could replace the coils on the project bike with newer type Ignitor sticks.....obviously with the necessary changes to the wiring..... Quote
Stu Posted January 23, 2014 Posted January 23, 2014 Yes you can do it and apparently it's easy enough you just have to make a loom for them The main problem is that you need to get the right length coil so they seal properly to stop water ingress Quote
Tango Posted January 23, 2014 Author Posted January 23, 2014 That may be the stumbling block Stu.....the bike is air cooled.....so the plugs don't go down inside the water jacket.....so there'd be nothing for the seals on the ignitor sticks to seal to..... Quote
