OK then all of you knowledgeable folks if I could pick your brains for a moment...
Whats the best way to remove you front brake discs for replacement? Mine seem to have seized solid to the wheel and I cannot even get the alan key bolts out that hold the disc to the wheel!
Any ideas are much appreciated!
I use an old spindle placed on the bolt and then give it a good wack to shock the bolt and unsieze it, works for me every time.
I ended up doing just that and all of them came out bar one which I had to drill out in the end.
I am sure the last person to put those discs on used a tube of locktite on each and every thread!
Wouldn't be a bad call to fit new bolts if they have all had grief to remove them. Good to here your sorted.
Yeah....you can probably get some stainless disk bolts.......and when you fit the new disks apply a very small amount of non-hardening loctite....the blue stuff.....can be got in a stick, a bit like a Pritt stick...... :wink:
Well now its all stripped down I think I might spray the wheel the right colour...the back one is silver and the front black, now wheres that spray can... :lol:
