honda xr125
Guest Leicesterdave
Honda xr 125 converted from road to off road use only. My problem is I want to wire neutral light to the handlebar .how do I go about it?
Effectively the neutral switch will short to ground when the bike is in neutral......so, if you have a hot feed to one side of a light and the other side wired down to the neutral switch the circuit will be completed when the bike is in neutral and the lamp will come on..... :wink:
and worth a thought if the bike is injected then it could also be wired to the ecu to ensure the ecu use the right fuel map and without a neutral light the bike wont run right :wink:
time to look at a wiring diagram :)
