Guest Posted April 24, 2014 Posted April 24, 2014 hi alljust hoping someone can help me out my son has no bought himself a yamaha aerox 50cc moped but like normal its been pulled around left right and centreive put most parts back together but just need to know where the oil pipe connect to the carbso i was hoping someone could send me a picture of a carb with all pipes connected to itany help would be gratefulregardsJohn Quote
Guest Posted April 24, 2014 Posted April 24, 2014 Hi John,Simple google search brought up this http://www.scooternations.com/showthrea ... ooter-CarbNot the same bike but possibly similar? Quote
Guest Posted April 24, 2014 Posted April 24, 2014 thanks for the reply , i did find that one on web but its differentmine has got the black plastic fuel bowljohn Quote
Guest Posted April 24, 2014 Posted April 24, 2014 Hmm is there not just one bit left with no pipe on it ?Usually a good idea to take pics as you take things apart so you know how to put back together, yeh I know that's too late now!Do you have a local bike shop / mechanic you could ask?Sorry I am so rubbish!Moved to Pitstop section Quote
Stu Posted April 24, 2014 Posted April 24, 2014 post a pic at different angles and someone will soon tell you Quote
Grumpy Old Git Posted April 25, 2014 Posted April 25, 2014 The picture on here looks OK - Should give you a clue.http://www.ebay.co.uk/itm/Carb-for-50cc ... t_60wt_928Or, failing that - just use g@@gle Images for the Aerox 50cc Carb. Quote
Guest Posted April 26, 2014 Posted April 26, 2014 thanks for the repliesjust one more question the bike has a 70cc piston n barrel upgrade on it and been told that may need to upgrade the size of main jetnow stripped carb down and it has a 68mm jet in it , so any ideas what size to put inmany thanksjohn Quote
Guest Posted April 26, 2014 Posted April 26, 2014 Hi john, will delete other topic and keep this one with all your stuff in, hope that's okay vickiPs... Did you get carb sorted? Quote
GazzyG Posted May 2, 2014 Posted May 2, 2014 Is it a Malossi big bore kit or some cheap chingdongchao jobby?If it's malossi, finding jet size should be relatively easy. Quote
