So my cbr 125 is revving like a mad up to 7-8k rpm on neutral, it looks like a carb is leaking the air. Does anyone know how to fix it without buying new carb? Thanks
Check that the manifold between the carb and the cylinder head is OK......no leaks or splits in the rubber.....and the screws holding the carb in place are not loose...... :wink:
Also make sure that your throttle cable isn't sticking..... :wink:
as above and make sure the choke isnt stuck :)
spray some wd40 in the area and if the revs change then you have found a leak
