Guest Posted August 28, 2014 Posted August 28, 2014 Looking at buying some new brake and clutch levers because I dislike the red patched ones I have...I've seen alot of "short" levers. Are they better than standard length ones?Looking at spending max. £40Thanks Quote
Tango Posted August 28, 2014 Posted August 28, 2014 I've got Pazzo short adjustable levers on the bike......I like them, but they aren't cheap.... Beware some of the cheap ones.....they can snap or bind.....see what others recommend.... Quote
Richtea Posted August 28, 2014 Posted August 28, 2014 I got some cheap no brand ones from eBay the quality was quite good but the fit was poor. On the TLR you have to pull in the clutch to start up but no go, the lever didn't have the piece on it to press the button behind it.But for £15 it was worth a punt. They fit fine on the gsxr though.I got some adjustable titax levers in the end,can't recommend them enough good quality and adjustment, no fitting probs bit pricey though think about £79 the pair Quote
Stu Posted August 28, 2014 Posted August 28, 2014 The problem you sometimes get with cheap leavers is they don't fit right and can cause the brakes to be on slightly all the time This coupled with binding brakes and a bit of heat and fluid expanding can lock the brakes on solid!! Not good when riding! Quote
Guest Posted August 28, 2014 Posted August 28, 2014 Ah yeah yeah cheers guys!And I saw those Tango but decided to go with some OEM replacements Quote
