Having problems with this thing. It won't seal. It's clean and undamaged , but sometimes it seals with engine off and most times it doesn't. Already drained the tank into the sump due to a leaking float valve. Thinking of replacing with two manual valves, one for main, second for reserve. Any thoughts?
Can you not get a fuel tap repair kit for it Alan?......maybe the diaphragm has a split in it?
had a problem with Chiras, ended up buying a new replacement tap from Kawasaki. wasn't overly expensive and not had a problem since
