Hi guys, my 97 XF650 cases could do with a cleaning up. What method are you guys using to get old cases looking good again?
Barcud
Depends on how bad they are and if they've got any kind of paint finish on them and its condition..... :wink:
I wipe the Speedy cases over with a bit of ACF50 on a rag as they've got a good black finish on them. The Honda cases are a bit tatty, so they're gonna need a good sanding down and repainting.......and possibly some polishing on the silver casings...... :wink:
So, there could be a few options mate...... :wink:
:stupid:
depends how bad they are and what you want to do with them
get some pics up of them
Hi guys, they're not too bad but would look better a bit cleaned up. You can see the cases on this pic.
close ups would be better when you get a min :thumb:
if they aren't too badly pitted then a wire wheel on a drill will take all the paint off very easily
then use an etching primer then repaint in a matching colour
or polish them up if you want!
I would repaint though
Thanks Stu. She is tucked up jammed behind the car in the back of the garage at the moment. I will get a couple of closer shots when she next comes out :)
Barcud
