markiedorg9999 Posted January 18, 2015 Posted January 18, 2015 right my 2012 honda cbf has got a light problen all of a sudden all the lights have gone of the headlight side light all the console lights rear tail light but brake light works n high low beam checked of connections for corrostion and all bulbs and wires to see if any bear plz help Quote
Tango Posted January 18, 2015 Posted January 18, 2015 Start simple, check the fuse.Wot Adam says.......sounds like a fuse failure..... Quote
markiedorg9999 Posted January 19, 2015 Author Posted January 19, 2015 checked the fuses and they are all ok Quote
markiedorg9999 Posted January 19, 2015 Author Posted January 19, 2015 been doing more research and the lights that are not working are powered direct from the altenator so there is no fuse in that circuit for the lights Quote
eastanglianbiker Posted January 20, 2015 Posted January 20, 2015 check the output of the alternator then if it has broken down and is putting to much charge out then it might be blowing all the bulbs Quote
markiedorg9999 Posted January 20, 2015 Author Posted January 20, 2015 the bulbs arnt blown thats what is strange Quote
Stu Posted January 20, 2015 Posted January 20, 2015 have you checked for voltage at the bulb connectors? also check your earths! if you have voltage there then you have a bad earth if no voltage you have no power to the front end it could be a wiring faulthave you changed the fuse or just looked at it? sometimes they look fine when they arent Quote
Tango Posted January 20, 2015 Posted January 20, 2015 I'm not sure if I'm reading this right, but dipped and main beam and brake light are ok......the problem is with the pilot light, rear light and console lights? .........if this is the case it sounds like a dodgy connector or broken wire somewhere....... Quote
Stu Posted January 20, 2015 Posted January 20, 2015 I read it as everything except the brake Bob Quote
Tango Posted January 20, 2015 Posted January 20, 2015 I read it as everything except the brake Bob Hmmm......I think we may need some clarification as to what's working and what's not Stu....... Quote
markiedorg9999 Posted January 20, 2015 Author Posted January 20, 2015 headlight high and low side light and tail light plus console lights all go off at same time then sometimes come back on one bye one then go off again iv replaced all the fuses but from what iv read online and that the lights are direct feed from altainator sorry if not explained very well Quote
Adam Posted January 20, 2015 Posted January 20, 2015 I've had the same on my bike, all the lights stop working and so does the dash and it was the fuse... Have you checked the new fuse to make sure that hasn't blown? It could be you're popping fuses due to a fault somewhere in the loom. Quote
eastanglianbiker Posted January 21, 2015 Posted January 21, 2015 also check the multi plug connectors for green corrosion and loose wires Quote
Kassa Posted March 9, 2019 Posted March 9, 2019 I have a similar problem but have no lights only a brake light when using the footbrake. Indicators also work. No dash no full beam no backbrake from handle. Help please Quote
McBert Posted January 10, 2020 Posted January 10, 2020 Front and back, as well as the dash lights are no longer working,,?? Just stopped working Anyone have any adviceIt's honda cbf 125.. Quote
ThePhatomfart Posted January 10, 2020 Posted January 10, 2020 Although this is an old Post , have you read through , check connectors and fuses and how is the battery charge Quote
CBF Posted March 20, 2024 Posted March 20, 2024 Old post..but this is a stator problem, needs replacing. Had this issue on a Honda CBF. Quote
