Suzuki B120
Hi
I recently inherited a Suzuki B120 and having no bike knowledge have decided to attempt to get in running.
I have got as far as purchasing the oils for the bike but the Hayes manual says the gearbox requires SAE 30 2 stroke oil. I can find some SAE 2 stroke oils online such as the below
https://www.machinemart.co.uk/shop/prod ... il-1-litre
I am not sure if this is usable as gearbox fluid for a bike? Or if anyone knows what I should be looking for?
Thanks for your help!
that machine mart one is no good for you as its for 4 stroke compressors.personally i would go with 10w/40 in the gearbox which is a fairly standard motorcycle oil and then make sure you have got either 2 stroke oil in the 2 stroke tank or premixed in with the petrol
Thanks, I have a 2 stroke 10/40 for the engine oil so I will just use that.
There are quite a few 'specialist' sites on t'web which provide for 'old bike' type oils, filters, etc. Going the cheapest route is not always benificial as old bikes need a bit of TLC.
Good luck with your project.
:cheers:
  • 4 years later...
Hello. I'm trying to restore my Suzuki B120. Can someone send me pictures of the pieces over the painting? (Coil, Electric Rectifier, end of pins holding the motor, ...) Thank you and greetings
Great fun the "Bloop" Please check the gearbox as I seem to remember the little blighters were all 4 down like a Fizzie and this can catch some people out.
Good luck with the resto and don't forget to take loads of pics!
Cheers
Ian
  • 2 weeks later...
Hi I have the Service Manual, Parts Manual and Owners manuals if their any good to you :wink:
or here
https://www.oldjapanesebikes.com/mraxl_GT_Resource/manuals_page/index.php
HI. how can I get the Owners manual? I need the arrangement of electrical elements (ignition coil, rectifier, flashers, ...). Thanks
