spykeeboi Posted May 11, 2015 Posted May 11, 2015 Hi folks ive got a 2000 zx6r j1 and after changing front brake pads after a binding issue the right hand caliper pads click now only when light pressure is applied then goes when more stopping pressure is applied however it makes no difference to braking but i will be changing the fluid soon. The pads that was in there originally were sintered so i put ebc organic pads in but these new ones havent got the mesh on the back of the pads...could it be that do you think taGaz Quote
Mr Fro Posted May 11, 2015 Posted May 11, 2015 Yeah, maybe. Might just be the pads getting pushed to the front of the caliper.Are there no anti-rattle things? Quote
spykeeboi Posted May 12, 2015 Author Posted May 12, 2015 Hi m8 the only things on there are the flat chrome plates that fix to the back of the calliper no shims or anything like that...can they be obtained from anywhere do you knowGaz Quote
