Hey all, long time no read! Hope you're all well. Anyways, been trying to change my exhaust this afternoon and the flange is stuck on! Bolts are out but is it just road holding it there or is there something I'm missing? Honda cbr 125
Can't beat a tight flange :mrgreen:
Anyway
Is this the end can your talking about? It could just need a good old wobble and a pull
Some can be tight fitting
Indeed! However I'm replacing the whole system and I mean the flange which joins the downpipe to the cylinder head. I'm replacing because of a complete split round the downpipe about 2cm from the flange. Meaning i cant use the downpipe for leverage
Same again really it just sounds like a tight fit
Once the bolts are out there should be nothing holding it
You shouldn't need a lot of leverage just a steady wobble to loosen it
All done now, Phooey and his tool kit were able to lend some assistance and it's now finished, sounds and looks brilliant! Thanks guys:)
Not often my tool comes in handy but tight flanges are my speciality :)
Maybe this should be moved to the adult section? :cheers:
