So trying to reverse drill the broken header bolt out and I've some how managed to actually to break the hole instead, as in a piece broke off the edge of the hole on the head itself.
Not a happy chap. What's my options here?
New head?
you can get them welded up and then drill and re tap them
Easy welding job - should only take a few minutes. The longer time / effort will be smoothing it down and re-drilling / tapping.
Get the price for a used head / engine and use this as a guide for the weld job quotation - Go for whichever is cheaper.
:cheers:
Crisis averted (I think). Managed to get the rest of the bolt out the hole. Screwed one of the old bolts and it takes a decent hold on the remaining threads. A shed load of locktite and maybe a spot weld for extra safety and it will be the next owners problem! ;-) Now just to get the other 2 out, hopefully I will have learnt from my mistakes..........
fit a stainless stud and use brass nuts :wink:
the stud will seize in as it will react with the alloy head and the brass nuts will strip or shear if things become a bit tight on the next removal
with brass been softer its easier to remove those and clean the threads up :thumb:
and good job on getting it out :)
