spykeeboi Posted July 13, 2015 Posted July 13, 2015 Hi folks ive got some of this to stick in the tank but thought i would seek advice on here first.... has anybody used it and did it work and would you recommend using it on a carbed bike....the bottle says 1 bottle will treat 40-50 litres and a minimum of 20 litres so i was going use half a bottle in a full tank of super unleaded...the bike is a zx6r j1.... what you think guysGaz Quote
Mr Fro Posted July 13, 2015 Posted July 13, 2015 I think you should clean your carbs properly!I've used most of those products in the past and exactly 0 of them worked! Nothing will beat a proper carb clean. Quote
spykeeboi Posted July 13, 2015 Author Posted July 13, 2015 M8 if i had the time to this i would but i use the bike for work and all it is the bikes running a bit lumpy on idle and when i rev it the climbdown of the revs seems a bit fluffy if u get what i mean so i was going to run a couple of tanks with this in but i was just wondering if it was safe to use in the carbsGaz Quote
Mr Fro Posted July 13, 2015 Posted July 13, 2015 Yeah, it's safe so long as you put the petrol version in. It's worth a punt but don't hold your breath. Quote
