I posted the other day about always going for a 7th gear and it made me decide to get a gear indicator from ebay. I've wired it up fully but you need to connect it to the neutral wire so it will display neutral as well as keeping it in sync. The problem is no matter where I connect the white wire to the neutral wire, it won't work. I'll go from neutral to first or second but when you go back to neutral, it doesn't change and just displays the gear you were previously in. I have tried connecting it at the neutral light and where it comes out of the engine but it doesn't change anything. Any help or advice?
Cheers
You sure you have the right wire? On my old bike when i fitted one of these (which i ripped off a week later because it didnt work properly) i believe the wire your looking for is a switched neg, and when its neg it displays N
I'm pretty sure I have the right wire, it comes from the engine and goes right up into the N dash light.
When I'm riding and putting in neutral it won't show 0 until I come to a full stop. What gear indicator you got?
Just a cheap ebay one...
http://www.ebay.co.uk/itm/291010095671? ... EBIDX%3AIT
Does it have a sensor above and below the gear lever??
if so, i bet you can get it to read a higher gear than that bike is really in i.e. 7th!
yeah it has up and down hall sensors. I think I saw somewhere that when you put the bike into neutral, it should overwrite whatever gear it thinks it's in and just display a zero. Once it displays zero, it resets position so it doesn't keep getting out of sync.
Depends if your lever can still move up when it's already in 6th gear. Some bikes the lever doesnt move, others the lever will move up but obviously not change into 7th.
If your lever can still move up whilst already in 6th, your display will go up a gear to 7th!
I had another look and realised something...
This is where I thought the blue wire went into the engine
But there was wire coming out the back of that cable
So I followed that all the way to the neutral switch
I hooked a wire around it and checked to see if it worked. It works if you go down from 2nd into neutral but it doesn't work if you go up into neutral. If you go up from 1st, you have to move the lever a touch down and back up again and then it displays the zero. I'm not sure if that's the best I'm gonna get.
It move up when in 6th but it doesn't have the extra little distance that it has when it actually changes up so as long as the sensors are spaced enough, it should be okay.
EDIT* I just realised that as long as the indicator is synced right, then I wouldn't go for 7th because I can see that it shows I'm already in 6th.
