Shirl Posted July 25, 2015 Posted July 25, 2015 Hi have just got one of these nd am having trouble fitting it to the handle bar. Tried to attach a pic but apparently its too big. The is a u shape bit that goes around the handlebar and a long plastic/rubber bit that I assume slides onto the other bit. 2 problems here, its hard to get it on and even if I could seems to long. confused :-/ Shirl Quote
NearOn Posted July 25, 2015 Posted July 25, 2015 Apologies I don't know the answer but I noticed you have a Moto cage? What do you think so far? I pick mine up mid August, can't wait!! Do you have an akrapovic fitted? Quote
Paul-Kent Posted July 25, 2015 Posted July 25, 2015 Pic of bits http://i17.photobucket.com/albums/b58/pcritcher/601AC074-8781-4F18-AAF2-4CFE91566C2D_zpszhzc3jgk.jpg Quote
Shirl Posted July 26, 2015 Author Posted July 26, 2015 Apologies I don't know the answer but I noticed you have a Moto cage? What do you think so far? I pick mine up mid August, can't wait!! Do you have an akrapovic fitted? Hi, Yea I like it. Ive done over 12000 miles since March so its been well tested. Its my first bike though so nothing to compare it to. Quote
Paul-Kent Posted July 26, 2015 Posted July 26, 2015 12000 miles! That's quite impressive![emoji41] Quote
Marky Posted July 26, 2015 Posted July 26, 2015 Shirl, you should have a C-shaped bit of plastic with a groove in (just to the left of the U-bolt in Paul's photo), try putting that between the U-bolt and the bar. As long as you can get both nuts on the U-bolt tightened up you should be OK. Quote
Shirl Posted July 26, 2015 Author Posted July 26, 2015 Marky, thanks I will try that. So the long plastic / rubber bit, what is that for Quote
