Anyone know where i can get an extendable breaker bar for the car? Halfrauds sells one but only online. Only going to be for changing car tyre if i get a flat so dont want spend loads if i can help it.
Get an off-cut of tubular steel from your local supplier.
:cheers:
You change your own car tyres? Most folk swap the wheel over and get a garage to fix / change the tyre! :shock:
Only if i have a flat when out and about. THe one they supply is as long as my hand.. No way in hell you can get the tyre off with it.
Might do that tbh.. I "adapted" my dads breaker bar with a long tube to get my front sprocket off :D I think i had a 6 foot long "Breaker bar". So maybe a small piece of tube over my spare socket wrench will do the trick!
try machine mart
or get a cheap one from the local market, boyes or wilko's
But.....
That is a wheel wrench - for use when changing wheels, not tyres (see my first comment). To change tyres you have to prise the tyre offf the rim (and you cannot do that with a wheel brace!). :? :?
You change your own car tyres? Most folk swap......
Sorry GoG, bad lingo use on my part.
It's just for swoping the spare wheel if i ever get a flat. Just bolts off and on.
But.....
You are correct but halfrauds call it a breaker bar. I confess I googled the Halfords web site to see it cause I thought the same as you.
Click and reserve it at your local store , then they'll email you when it's ready to pick up.
Very syrprised that it's not available in store thou.
Some of the online only stuff comes direct from the supplier or even from another smaller company that sells through Halfords, those items can't be collected at store at all as they don't hold stock of them in store or their distribution centre.
