funinacup Posted June 5, 2016 Posted June 5, 2016 Hmm this is worrying! The speed four has a datatool system 3 installed. It's working fine but it's very sensitive. Once I pass I'll have the bike parked on the street and I'm worried it'll constantly be going off. I don't want to turn it off as that kinda defeats the purpose of having a blaring alarm...It's a system 3 I've got too and yes it is sensitive but I've never had it go off on its own, that said I keep mine in the garage. The main problems I have are it has a mind of its own sometimes when I try to enable/disable non standard features, like service mode for exampleSent from my Nexus 10 using TapatalkMine goes in and out of service mode no problem with one of the fobs. The other is a bit temperamental. Will see about turning the sensitivity down a bit. Quote
funinacup Posted June 5, 2016 Posted June 5, 2016 You can turn the sensitivity down on themJust read through the manual and can't see a way to turn the sensitivity down.. Quote
mozza83 Posted June 5, 2016 Posted June 5, 2016 There's no sensitivity setting on a s3 but I have heard of someone who mounted a layer of foam between the alarm box and the bike which helped.Sent from my Nexus 10 using Tapatalk Quote
Stu Posted June 5, 2016 Posted June 5, 2016 There's no sensitivity setting on a s3 but I have heard of someone who mounted a layer of foam between the alarm box and the bike which helped.Sent from my Nexus 10 using Tapatalk yes you are right! My s4 had sensitivity! Quote
mozza83 Posted June 5, 2016 Posted June 5, 2016 Have you had any problems with your s4. My pal has one on his Strom and he's happy with it.Sent from my Nexus 10 using Tapatalk Quote
Stu Posted June 5, 2016 Posted June 5, 2016 I had no problems at all with the S4 or the S3 both on previous bikes I have no alarm on the current bike The only thing the alarms did do was go in to battery saving mode if left a long time and not on a charger then you had the set the alarm off by turning the ignition on then turn the alarm off Quote
Lumor_uk Posted June 9, 2016 Posted June 9, 2016 I have a 1998 data tool and only one remote. Paranoid as hell I'll lose it Quote
Blackdog Posted February 4, 2017 Posted February 4, 2017 New to Forum, I have just bought a bike with a datatool Duo Alarm, which comes with 2 fobs,Problem is, only 1 fob works. Any one know how to program the second fob..Cheers Quote
Stu Posted February 4, 2017 Posted February 4, 2017 Duo alarm? or immobiliser? pretty sure the duo is just an immobiliser ps welcome to the forum Quote
JimminyBillyBob Posted May 19, 2020 Posted May 19, 2020 Hello!Both my fobs to the immobilizer stopped working and I haven't had much joy of this installment so I'd like to disable it. All the wires are black and I am slightly worried I'll make things worse. So I am glad I found this forum and hope you guys are willing to take time helping me out. My bike is a Suzuki GSF 600 Bandithttps://imgur.com/vkuNQyN' alt='IMGUR>'>https://imgur.com/acNpTb2' alt='IMGUR>'>Thanks in advance! Quote
