phil4 Posted July 31, 2016 Posted July 31, 2016 Hi,Started my bike up this morning ahead of a nice ride out, and was presented with a new error - PKUP 34.0. Suggesting the an error with the "pickup sensor".The bike fired up ok, and the error light vanished while running. No issues with running. But when I'd got back home, and turned on the ignition (but not started it), the same error appears.So, does anyone know what the Pickup sensor does? Is it critical? important? needed? Am I damaging things running the engine with the error? If it's only the sensor that's faulty, then it looks like replacing it is just a case of getting the fairing off and a 30-50quid part. I just wonder if it's something I need to do before I next ride or not?TIA. Quote
Stu Posted July 31, 2016 Posted July 31, 2016 you might have had a slight missfire while cranking causing the error I wouldn't worry too much about it if its gone but if it keeps happening you might need to investigate Quote
Guest Posted July 31, 2016 Posted July 31, 2016 Pick up sensor is normally crank sensor. Often flagged by dozy starter or battery. Quote
ThePhatomfart Posted July 31, 2016 Posted July 31, 2016 Take a look at this http://www.ducati.org/forums/1098-1198/31357-pk-up-sensor-error-34-0-fix.html" onclick="window.open(this.href);return false; Quote
phil4 Posted July 31, 2016 Author Posted July 31, 2016 Thanks All.The bike lives on a battery charge thingy, and I've seen enough lights on there to suggest the battery is on it's way out.... so quite possibly that issues (especially as it was before I got going the error came up).Just turned the ignition on now, and no error, so that's a good start.And Spanner, thanks for that link, if I come to change the sensor, that'll be my go-to page.Thanks again! Quote
