seval Posted September 17, 2016 Posted September 17, 2016 My cbr 600 f3 1997 want go more than 80 km/h in 3,4,5,6 hear, in first gear it goes to red line and about 130 km/h in second it goes about 90-100 km/h and it starts sputtling, in 3,4,5,6 gear it stays at 6k rpm and it want go more than 6k rpm, i let the gravity feed to carburators with full tank but the problem is the same so its not fuel pump problem, please help what is problem with my bike, any similar experiences??? Quote
Valko Posted September 17, 2016 Posted September 17, 2016 Hello and welcome Get a new OEM air filter.If that does not help check the starter relay and ALL electrical connection - bad connection can do that to you. Quote
Tango Posted September 17, 2016 Posted September 17, 2016 Welcome to TMBF mate. ......pop over to the Newbies section and introduce yourself to the guys when you can. ....... We need to know a bit more about the bike.....ie, when was it last serviced, have the spark plugs been replaced recently, is the oil good, air filter changed, standard exhaust with no leaks?Sounds to me to be related to the spark.......coil breaking down......problem with the crank sensor......etc Quote
