I have an old 86 trx250 fourtrax that I have been restoring. The other day I cleaned the carburator out but didnt take anything much apart. When i put it back in and turned on the fuel it all came pissing out of the overflow valve and wouldn't stop. Any help is appreciated.
Cheers
Hi and welcome to the forum
Sounds like the float is stuck open and just allowing the fuel to flow through
have you set the float height too?
Never worked on carburator before so I wouldn't know how.
You might want to invest in a workshop manual and find the settings for the float height
Hopefully spanner will be along soon as he is a good source of manuals and may be able supply you with a free downloadable one
sounds like sticky float, clean the pin for the float and check the needle is still there.
you can test the floats are moving buy blowing down the fuel line, the float lifts
