seanburn899 Posted March 5, 2017 Author Posted March 5, 2017 Sent from my HTC One_M8 using Tapatalk Quote
ThePhatomfart Posted March 5, 2017 Posted March 5, 2017 OK , I take it the red pipe is fuel and goes to the pump , where does the black one above it go Quote
seanburn899 Posted March 5, 2017 Author Posted March 5, 2017 Same place pal the 2 met near pump and go into on Wren next pic if zoom into near pump u will see t peace that connects them on the front of pet cock it's says full and res Sent from my HTC One_M8 using Tapatalk Quote
seanburn899 Posted March 5, 2017 Author Posted March 5, 2017 Is to big to send pallSent from my HTC One_M8 using Tapatalk Quote
ThePhatomfart Posted March 5, 2017 Posted March 5, 2017 It just seems a bit strange cos that petcock should be attached to the tank, not to the body, what year is this bike again Quote
seanburn899 Posted March 5, 2017 Author Posted March 5, 2017 2004 Sent from my HTC One_M8 using Tapatalk Quote
TimR Posted March 5, 2017 Posted March 5, 2017 It just seems a bit strange cos that petcock should be attached to the tank, not to the body, what year is this bike again Think the cable tie may be a clue Quote
seanburn899 Posted March 5, 2017 Author Posted March 5, 2017 I just can't figer it out at tried almost every thing as meany conbersations as can think of tired siting thinking logically just can not get any father forward starting to make me think is it the actual carbs them self's coz like I say as soon as I block off96-98% of its air flow it's closer to starting can here it so tank back on its back to square one tottaly dead if u get lol Sent from my HTC One_M8 using Tapatalk Quote
seanburn899 Posted March 5, 2017 Author Posted March 5, 2017 TIMR I Neva even noticed that cable tie clue to what how fuked I am with this thing now lol Sent from my HTC One_M8 using Tapatalk Quote
ThePhatomfart Posted March 5, 2017 Posted March 5, 2017 Will look into it again,but I think what you got there is a bit of a bodge up, maybe you could ask the guy who put it together how he sorted the vac pipes,it shouldn't take too much thinking to get round it , but its all about those vac pipes from the carbs, somewhere along the line there's a vac pipe not connected to the right position, the front and rear carbs are creating vac but somewhere its getting destroyed keep trying and I'll look into it and see if I can come up with the answer Quote
TimR Posted March 5, 2017 Posted March 5, 2017 TIMR I Neva even noticed that cable tie clue to what how fuked I am with this thing now lol Sent from my HTC One_M8 using Tapatalk Where spanner says that the tap should be tank mounted and seems like a alternative petcock/fuel tap has been used . Quote
seanburn899 Posted March 5, 2017 Author Posted March 5, 2017 I have tired getting in touch with the guy no joy I need to get my other fone fixed to get his address an yeah I agree one of those is wrong just witch one an where I thought an think air2 has something to do with it like an thank you so much Sent from my HTC One_M8 using Tapatalk Quote
ThePhatomfart Posted March 5, 2017 Posted March 5, 2017 Try this, if you've got a length of fuel line, take off the fuel line from the pump to the carbs, attach the pipe to the out let of the pump, put the free end into a petrol can/bottle , turn over the engine and check for fuel coming out, if you get fuel out of the pipe then vac pipes are working and its something else, which can be looked into Quote
seanburn899 Posted March 5, 2017 Author Posted March 5, 2017 Will be the morra will get more Fule./line clips for some strange reason got that sinking feeling it's the back half or vac side where the sliders an Dias are at one point was thinking I had put the crabs back wrong but cheeked with pics an all that that it was OK kinda wish I could cheat Fule straight on to crabs have the vacs drawing on the back of carbs. Make it all work simple lol Sent from my HTC One_M8 using Tapatalk Quote
ThePhatomfart Posted March 5, 2017 Posted March 5, 2017 If that fuel comes out the pump ,your vacuum side should be alright Quote
seanburn899 Posted March 6, 2017 Author Posted March 6, 2017 OK doki pall be round 1030 when I get bk home lol Sent from my HTC One_M8 using Tapatalk Quote
ThePhatomfart Posted March 6, 2017 Posted March 6, 2017 Hi did you say when you got the bike it ran for 30 seconds then nothing, if so there might of been enough petrol in the bowls, have you cleaned the carbs Quote
seanburn899 Posted March 6, 2017 Author Posted March 6, 2017 Well the 30 secs was roughly after I handed over cash an event to ride back home she literally last 30 seconds now currently for her to start I need to help her out with a quick blast or something highly flambe straight down the carbs once that has been used she dies will not restart unless assisted I dunno I just can't seem to get past the carbs yep been cleand over an over with can of carbs cleaner Sent from my HTC One_M8 using Tapatalk Quote
seanburn899 Posted March 6, 2017 Author Posted March 6, 2017 Sent from my HTC One_M8 using Tapatalk Quote
seanburn899 Posted March 6, 2017 Author Posted March 6, 2017 See that holes in top of carbs the cover ones brass ones to be specific if I blow the center pup at back Fule comes out there I'd I do the same on back hole where it lops into side that one dose it to the black sliders do not seem to move the butterfly backs perfect Sent from my HTC One_M8 using Tapatalk Quote
ThePhatomfart Posted March 6, 2017 Posted March 6, 2017 Hi ,did you take the jets out and clean them? Quote
seanburn899 Posted March 6, 2017 Author Posted March 6, 2017 Yep had it all to pieces made sure clear how Eva I do not have air compressor to blow them out lol Sent from my HTC One_M8 using Tapatalk Quote
