Hello from Hamburg. Question about honda cbx750f 1986 cylinder firing order. Can anyone tell me in what order should be the coil leads connected? I cant get the engine run properly? I was somehow under impression they should be firing cylinders 1&4, 2&3. The leads are not numbered.
Hi Stu thanks for reply. The coil one fires 1and 3 , second coil 2 and 4? Cylinders are from left to right?
Hi, Firing order on 99% of inline four's is, 1-2-4-3, and the coils fire, 1 and 4 ,and, 2 and 3, which is what your Honda is, ok, Motorcycle engines run in banks of two's, two up, and two down.
:stupid:
Deffo....1 coil fires plugs 1 & 4 and the other coil fires 2 & 3....... 8-) So it sparks on the compression and exhaust strokes on all cylinders..... :wink:
