Guest Posted October 1, 2017 Posted October 1, 2017 MOTORCYCLE: ZX636 / ZX6R 2003 B1HPROBLEM: Lost my motorcycle keys at work (lorry driver) Motorcycle stuck at work No spare keys.HELP NEEDED: A Tech to come to my Motorcycle In Birmingham (can try get it moved back home to Kidderminster or to you if I can) Change full lock set, Barrel, Petrol cap, rear seat lock. Remove current alarm (Meta) & install new one either a Meta or Spy 5000m. I have the lock set now but wanted advise on alarm/ immobiliser ideally wantes remote start. IF ANYONE CAN HELP WILL HIGHLY BE APPRICIATED THANKS. Quote
Mr Fro Posted October 1, 2017 Posted October 1, 2017 Have you got KISS?If you have then you might want to give a Kwak dealer a call as you'll likely need a master key to re-jig the ECU. Quote
