Guest Posted October 12, 2017 Posted October 12, 2017 Here's a few fixes for some of the most annoying design flaws.Cylinder head thermostatRemove it, before it seizes shut.http://www.laboutiquedelamoto.com/sites/default/files/styles/600px_marca_agua/public/cm151902.jpg?itok=sApNBlHaCarburetor jetting issues This postOil filler capOEM transmission oil filler plug gets in the way of carburetor float chambers, which makes sliding out the carb for jetting changes more of a chore.Voca VCR-SD9192/BKBanana skin brake pedal replacementConti 1614TD0005 (knurled tip)http://www.dam-sport.net/media/catalog/product/cache/1/image/800x530/0f00551ab62b14934f2cf581d3f166c3/1/6/1614TD0005.jpgCoolant / oil leakageReplace those metal washers.Cylinder head and radiator thermoswitch plugs: M14 fiber washers.Oil sump and clutch cover plugs: M10 fiber washers.Ignition replacementMVT Millennium EXT 111Only ground the blue wire if you want to restrict top speed.http://www.dam-sport.net/media/catalog/product/cache/1/image/800x530/0f00551ab62b14934f2cf581d3f166c3/E/X/EXT111.jpgLong throttle twist fixDomino 2203.03-02Throttle cable: Derbi 863069http://www.treatland.tv/v/vspfiles/photos/domino-throttle-2203.03-02-2.jpgAnalogue speedometer conversionSpeedometer: Derbi 864515Speedometer cable: 00H0161602117" SM wheel hub sensor: 00H0161405121" enduro wheel hub sensor: 00H01613051Bikes manufactured from 2013 with mag wheels require a 2006 - 2012 spoked front wheel.Fuel gauge substitutePut a 2mm blanking cap on the auto vacuum carb nipple.Derbi Cross City 125 manual fuel tap: 00H00404181This features a reserve fuel straw..http://i751.photobucket.com/albums/xx157/tomsmithwork/DSCN2311.jpg?hotlinkfix=1507375386698Secure the rear fender by drilling straight through its mounting lug holes with a 5mm bit. Use 5x50mm screws, 5mm star washers, and nyloc nuts. Acerbis's enduro rear fender bag is a perfect fit for Hünersdorff's Fuel Friend 1L container.5mm plastic straight piece between fuel tap - carburetor line. Refill container from the bike's tank using the manual tap.SX 50 chain guard rubbing off tyre wallUse spacers, or grind swing arm mounting lugs off. Single seat bikes don't require chain guards for public road use.2006-2009 headlight strapsWhen they split, replace them with Polisport Halo straps.Preventing a damaged batteryWithout a lid, it bounces around. Use a few pieces of high density foam underneath, and around it.RX 50 soft fork spring fixMarzocchi forks: use SX 50 springs and preload spacersKayaba forks: use SX 50 springs Quote
fastbob Posted October 20, 2017 Posted October 20, 2017 Alternatively one could just get a proper motorcycle. Try to avoid anything with multiple design flaws . This is my proper motorcycle.http://i.imgur.com/25POB07.jpg Quote
