Matt0503 Posted December 21, 2017 Posted December 21, 2017 Hi guys, i have a few slight problems with my 50cc, i put it together after buying it in pieces and im having a problem with the revs and idling.So after i worked out that i had a leak in the vacuum from the manifold to the carb, after i fixed that by blocking the pipe with a screw it now has ALOT more power, but it dies on low revs even after messing with the carb settings for a bit. It also has a problem when i rev it the revs on the dadh drop completely to 0 but the bike is revving, the revs also fluctuate on the dash when i let go of the throttle.Thanks for any help in advanceAny help is appreciated. Quote
Guest Posted December 21, 2017 Posted December 21, 2017 Still reckon you don't need the manual, then? Quote
Matt0503 Posted December 21, 2017 Author Posted December 21, 2017 I will try to make it work without it its more of a challenge and a puzzle that way. Thanks anyways Quote
Tango Posted December 21, 2017 Posted December 21, 2017 Sounds like either a dodgy connection to the display......or the voltage from the charging circuit is not correct..... Quote
Matt0503 Posted December 21, 2017 Author Posted December 21, 2017 Thanks, i was thinking it would be something to do with the connections, i didnt get much time today but i will surely check out the connections tomorrow, i have already checked the ground wires but i guess its one of the other ones. Do you know why it maybe jumping up and down? Is it also a electric problem or is that to do with the carburettor? Quote
Matt0503 Posted December 28, 2017 Author Posted December 28, 2017 Hi guys, i checked and cleaned all of the connections possible on the bike and the problem still occurs, is there anything else i can try and do? The battery is brand new Quote
