emmajaneg Posted December 30, 2018 Posted December 30, 2018 Hi there, my boyfriends YBR 125 has completely messed up. His bike will not turn on properly, he is having to faff with the wires to get the ignition to turn on. Can anyone recommend something we can do, some cheap wires to order to fix it? Thanks Quote
mikestrivens Posted December 30, 2018 Posted December 30, 2018 Get a wiring diagram and a multimeter is the first step. The next step would be to find a competent electrician. Quote
Magpie84 Posted December 30, 2018 Posted December 30, 2018 Oh no mine had issues when I first got it and it ended up needing a whole new wiring loom. I wish I could offer some advice but I'm clueless I just hope it ends up being an easier fix than mine. I know when mine was playing up the engine light flashed which indicated what the fault might be, for example mine did 3 long flashes, to show the first number, then 3 short flashes to show the second number. That showed there was something wrong in the ignition coil or in my case a loose wire in the head light that was shorting everything out and then proceed to get worse every time they fixed one thing another went wrong These are the other codes and what they mean. Quote
Grumpy Old Git Posted January 1, 2019 Posted January 1, 2019 Strip, clean contacts, remake earths, rebuild = Sorted! Quote
