Dtulleth Posted February 24, 2019 Posted February 24, 2019 Hi, just changed my clutch cable, getting up gears but only down to third, any advise would be most grateful Quote
Tiggie Posted February 24, 2019 Posted February 24, 2019 Sounds like the cable is out of adjustment. Possibly too slack? You will find an adjustment nut (at the bottom end of the cable usually) similar to the one pictured that you can use to take up the tension Quote
Dtulleth Posted February 24, 2019 Author Posted February 24, 2019 I've tried all that but does not seem to doing anything, Quote
