Hi, hoping to get some insight here, my CG125 engine keeps cutting out when the revs drop down low while driving, I can be in any gear and if I'm not revving the engine it'll cut out. Especially bad when coming to a stop in 1st again if I don't rev the engine it cuts out.. Once it's dead it struggles to start again. Electric start, choke on or off doesn't matter. Does anyone have any ideas?
Just in addition, it starts if the choke is on and immediately flicked off, you can ride it until the revs drop.. Then repeat..
Wild guess, you have a stuck float valve which is causing the engine to flood when you stop . Does it pick up again if you rev it and then die again when it returns to idle speed . Also can you smell petrol when it dies ?
