Hi
I have a 56 plate triumph daytona 955 but seem to be suffering with electrical issues.
I have had the rectifier replace with a mosfet one and due to fuses having previously burnt out I have had 1 x 30 amp replaced with and inlane fuse box.
However it has failed and the other 30 amp has also burnt out.
I managed to get 600 to 700 miles but then have been away and left the bike on a trickle charger. I have then come to use the bike and upon starting up the dials have all died and I have now found that the 2 30amps have burnt out again.
Has any one had anything similar or know of a fix for this?
Thank you
Sounds to my like you have high resistance somewhere causing things to get hot either that or the reg/rec is faulty
time to dig in and check wiring and get the multimeter out
Same thing happened to a friend of mine - apparently it’s a common problem and not a cheap fix just replacing the 30A fuse with an inline one. There are a numbers of forum’s giving advice like this one for example
https://www.triumphrat.net/daytona-deliberations/177358-daytona-955i-2003-electrical-problems.html
Good luck trying to find someone to fix it my mates was off the road for weeks trying to resolve the problem
