Hi,
I’ve had electrical gremlins with my CBR600RR 2004 for some time now, so have decided to replaced the whole loom and ECM with one I found on eBay that was taken from a track bike. The new loom has come with a Power Commander 3 USB, gear indicator and an additional Killswitch fires from the fuse box as it has no HISS. Not sure if it might be an American loom and ECM.
I have removed the old and fit this but am unsure with a few connections. There are a couple on the additional Killswitch and a couple of blue plugs which I think have something to do with the power commander.
I’ve emailed the seller a couple times but haven’t had a reply.
Could anyone help with this, would be much appreciated.
Please see photos.
Thanks
Martin
I don’t know. It’s all been taped together with the loom. I could unwrap to find out but I’m sure they are anyway
The bottom one looks as though its the connector that goes between the loom for the injectors
the ring is an earth and the other could be gear position sensor or timing of some sort
