The VFR doesn't have many places to run cable. I might have to run close to the engine. I don't trust normal PVC wire. What should I use and where can I get it?
I've never worried about it or had a problem but if you think you will you can get heat proof sleeving on eBay or Amazon for the bit of wire that runs close to the heat source.
