Help With My Lexmoto Fmr With Upgrades Im Doing
I was wondering which main jet i should be using for a 152qmi i have a :
• Gy6 Performance Exhaust
• Performance Air Filter
• Peformance CDI + Ignition Coil
Just need to know what size i should be using for performance and should i be changing the rollers or carb itself its all stock i just changed few bits
I'm thinking that you actually have the 125 cc version . There's no way anyone here is going to give you a definitive answer . I suggest that you buy a few sizes of jet and simply experiment until you achieve the optimum performance . I think you are already aware that if you produce more power you will have to change the rollers to make best use of it . Good luck.
Hi and im looking to change rollers and clutch springs but which is best weight rollers and roughly which jet sizes am i looking to test also how would i know as i might need to mess around with air fuel mixture
With the greatest of respect , and it's got nothing to do with it being a Chinese scooter , I really don't think that you are going to get any specific answers from this forum . I've had a look at what performance upgrades are available for your scooter on eBay and I have to say I'm very surprised at how much is available and how cheap it is . High performance carbs and racing belt and roller kits are available so I'm guessing that these are the missing parts of the jigsaw . You would be much better off joining a FB group that's devoted to scooter tuning to be honest .
