If the key is stiff to turn in the ignition, is it ok to spray WD-40 on it to try and help?  Or could it have any detrimental effect on electrics?...  I just want to make sure I'm not doing anything that could detrimentally affect the bike...
Thanks
Wd-40 won't have any issue with electrics. But it is a degreaser so will melt off any lubricant that's already in there. It'll help for now but you'll need to use some proper dry graphite or similar in the long term
