Posted (edited)
Wouldn't it have been a little more polite to introduce yourself to the rest of the forum first rather than dive in and ask the same question 3 times?
Edited by KiwiBob
I dunno. I like the username.
If you're having carb issues you probably want the stock airbox and filter on. Or just mess about with jets and mix screws until it gets better. And needle clip height.
Other than that my preference is for these hepaflows
But really, if you have a non standard air filter you will need to fanny about with the jetting. Not impossible.
17 minutes ago, Air filter advice said:
I didn’t realise kiwi Bob would be so sensitive, I presumed this was a forum to share knowledge and get advice rather than creating friends
It’s a bit like walking into a room and saying “I want this” without having said anything else to a group of people you don’t know.
here is a great place to make friends and get help. I have had loads. If you were wanting to make friends you might start with something like:
hi I am Jeremy, came here because I am having a difficulty and hoping you can help.
some here will mind some won’t. You have a better chance of getting what you want with nice words :-)
If you've got a pod filter on already, leave it and play about with the carb. Pretty much any filter you'd replace it with is going to give similar issues because it's no longer got the restriction of the stock air box, which the carb is setup for.
Have a look at this guide, see if it helps. https://www.caferacerwebshop.com/en/blogs/blog/how-to-rejet-your-cafe-racer-carburetor/
