Mississippi Bullfrog Posted April 24, 2021 Posted April 24, 2021 3 hours ago, Rkel1988 said: Looking to buy bobber black! Plenty in dealerships. It's a bike a lot of people buy then find it's not for them. But before you buy see if you can try the original Bobber, unless you're set on the looks of the Black. I tried both and found the slimmer front end on the Bobber flows better on the twisties. The Black corners like it's on rails but you do need to physically turn it into the bend. Contrary to what seems obvious the braking between them isn't as different as you'd think. Good luck with looking for the right one for you. There's none on the Bobber forum right now. Quote
