Stu Posted June 13, 2021 Posted June 13, 2021 www.telferizer.com The Telferizer is the perfect solution for mounting GPS systems to sports bikes and sports-tourers. The mount has been tested throughout Europe on all terrains and in all weather conditions for 100,000+ miles. It has proven itself to be ultra reliable and is vibration free. The Telferizer also has a unique central mounting position which leaves clocks unobscured even when using a tank bag. If your GPS is TomTom, Garmin, NavMan or Magellan then we can give you a custom solution that will enhance your cockpit view rather than obscure it. The Telferizer Ram Mount can be fitted in seconds and requires no specialist tools The Telferizer enables you to quickly remove the GPS unit from your motorcycle when parked in a public place Guaranteed completely Ram Mount compatible Products tested and endorsed by MCi Tours. 100,000 miles trouble free installation Rubberised unit absorbs vibration Fully waterproof Suitable for data-loggers (track days) Camera mounts available iPhone 3, 4, 4S, 5 Ball size diameter Ram Mount 25mm Lifeproof 22mm iPhone 20mm Garmin Nuvi 17 & 16.2mm TomTom 16mm Contact us Telferizer Motorcycle RAM Mount Systems 95 St. Lesmo Road Cheadle Heath Stockport Cheshire SK3 0TZ United Kingdom Tel: +44(0)161 476 5701 +44 (0)796 602 6532 2 Quote
Stu Posted June 13, 2021 Author Posted June 13, 2021 I have personally used one of these on the FJR for 6 years and they are a solid mount and work really well 1 Quote
