Guest Posted June 12, 2008 Posted June 12, 2008 Umm...Take these questions in the spirit of the uber-tight budget on which I'm on! 1) I hate the look of back boxes, but I'm starting to think as my bike will be predominantly for commuting, it may be a practicality I have to put up with.Is the Givi the best bet (am thinking I could then swap it to another bike as and when required)? How cheaply could I do it? Or is there another range I should consider?2) One of my first jobs with my 'new' (and I use the term loosely) bike is to remove the tank. Haynes says on re-installation to use a torque wrench to the correct settings. How necessary is this? I mean, I guess it's one of those "don't use it if you don't want, but don't coming running on here when it all goes pear-shaped". If I have to get one, can anyone recommend one..?Cheers all, as ever Quote
nman1 Posted June 12, 2008 Posted June 12, 2008 I commute and have to take a clean shirt, waterproofs etc in most days and I manage with a good ruck sack. Providing it`s waterproof it has served me well for the last two years. Quote
Guest Posted June 12, 2008 Posted June 12, 2008 if you want a torque wrench-I got one you can borrow. Quote
cyberwolf Posted June 12, 2008 Posted June 12, 2008 if you want a torque wrench-I got one you can borrow. but i think you find it easy to get to justarider Quote
Stu Posted June 12, 2008 Posted June 12, 2008 it is basicly covering their own ass all bolts should be to a specific torque but not everyone uses a torque wrench even mechanics **if you was doing a full engine rebuild i would say get one but as its just the bolts on the tank im sure you would be ok to just tighten them up** i dont think your tank is going to come flying off when riding but if you dont use a torque wrench just recheck the bolts again after about 1000 miles or so **disclaimer dont blame me if it goes t*ts up Quote
Guest akey Posted June 12, 2008 Posted June 12, 2008 luggage, I used a tank bag for years to carry all my stuff in, also have a soft tail pack (oxfor first) if i needed to take more stuff.Dont need to worry now as the tiger has hard panniers Quote
Guest Posted June 13, 2008 Posted June 13, 2008 If you do decide to invest in a torque wrench in the future, you'll find you actually need 2 ...A big boooger for very high torque settings - like axel bolts for example ..And a ickle one - for wee stuff ...It may be worth your while expanding your tool kit and learning moreabout your bikes mechanical bits and pieces - not least because it can save you a small fortune on servicing..... Quote
Guest Posted June 13, 2008 Posted June 13, 2008 That's pretty much what I was thinking. Justarider and Cyberwolf - thanks so much for the offers - I really appreciate it. Screwfix have torque wrenches for £12:50 - I guess at that money, it's a bit of a no-brainer Quote
