Dena Posted October 25, 2021 Posted October 25, 2021 hi I’m new here is there anyway to lower the new trident ie get a shorter rear shock if so where from pls Quote
bonio Posted October 25, 2021 Posted October 25, 2021 Usual way to lower a bike is to install longer dog bones - the part that attaches the bottom of the rear shock to the frame. They're usually around £40 or £50, but it depends on the bike. If you lower the bike by more than an inch you'll probably need to lower the forks (you don't need any parts for this) and perhaps shorten the side stand. Quote
Yorky Posted October 25, 2021 Posted October 25, 2021 2 minutes ago, bonio said: If you lower the bike by more than an inch you'll probably need to lower the forks (you don't need any parts for this) and perhaps shorten the side stand. To be precise you actually raise the forks / lower the triple clamp 1 Quote
