My 2009 Honda Hornet 600F has just produced a new fault, if I indicate stationary Left/Right they blink as they should but when I rev or accelerate away they go solid, anyone got any experience with this???
Check the output from your charging system as the rpm rises. Put a multimeter across your battery and watch the voltage when you raise the rpm. It shouldn't exceed about 14v.
Are they the OEM units or have you fitted aftermarket indicators?
As far as I am aware they are the OEM units
