Tom M Posted July 16, 2022 Posted July 16, 2022 hi there i was wondering wether anyone new the valve clearances for a cb125 k5 (German) as the ones in the workshop manual i have say the inlet needs to be 0.003" and the exhaust need to be 0.004" but when set up to these tolerances the engine is extremely noisy and taps like hell. can anyone help? Quote
oldgrump Posted July 16, 2022 Posted July 16, 2022 Well I would say inlet was correct at 0.003" or 0.08mm, and Exhaust would be 0.005", or 0.12mm. You did set engine up in correct position before doing the clearances? As for why they are noisy at that clearance, no idea!! were they noisy before you did them?? Quote
fredc Posted July 17, 2022 Posted July 17, 2022 did you do it hot or cold the gaps close as the engine heats up Quote
