Greenzy03 Posted August 13, 2022 Posted August 13, 2022 I’ve got a 2005 70cc Derbi Nude and I’m fixing it up. However, the indicators and Speedo go crazy when it revs or is jolted. The speedo will jump around from 5mph to 35mph if I Rev the bike at stand still and the indicators just go absolutely crazy. What could be causing this? I’m thinking a loose connection to low battery? Quote
Mississippi Bullfrog Posted August 14, 2022 Posted August 14, 2022 Put a multimeter on it to check the voltage as the revs rise. I bet they are going too high, in which case the regulator has failed. 2 Quote
