New to this whole forum thing so bear with me.
So basically, I've had my Honda CB125R 2019 for about 7 months without a problem, the front indicators act as DRL's, but now for some reason only the left one comes on and the right will only come on once I activate the indicator and cancel it.
Any suggestions as to what the problem could be, Thanks ✌️
I'm pretty sure you'll find there's a bad connection somewhere. Time to dig out the multimeter and get checking.
They are usually in a connector but if you're unlucky it could be within a wire. Much more likely to be a bad connector though.
